跳转到主内容
Lenovo ThinkPad T480s Speaker Replacement
你所需要的
  1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Speaker Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Speaker Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad T480s Speaker Replacement: 步骤 3 中的图像 2,2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Speaker Replacement, Battery: 步骤 4 中的图像 1,2 Lenovo ThinkPad T480s Speaker Replacement, Battery: 步骤 4 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Speaker Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 5 中的图像 3,3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Speaker Replacement, Speaker: 步骤 6 中的图像 1,3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: 步骤 6 中的图像 2,3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: 步骤 6 中的图像 3,3
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s Speaker Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad T480s Speaker Replacement: 步骤 7 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s Speaker Replacement: 步骤 8 中的图像 1,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 8 中的图像 2,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 8 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s Speaker Replacement: 步骤 9 中的图像 1,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 9 中的图像 2,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 9 中的图像 3,3
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s Speaker Replacement: 步骤 10 中的图像 1,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 10 中的图像 2,3 Lenovo ThinkPad T480s Speaker Replacement: 步骤 10 中的图像 3,3
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
结论
Sarah Westberg
于03/11/19注册
23,372 声望
创作了70篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 19
过去 30 天: 56
总计 1,362
