跳转到主内容
Lenovo ThinkPad T480s Antenna Kit Replacement
你所需要的
  1. Lenovo ThinkPad T480s Antenna Kit Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 2 中的图像 3,3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 3 中的图像 2,2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Antenna Kit Replacement, LCD Assembly: 步骤 4 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement, LCD Assembly: 步骤 4 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement, LCD Assembly: 步骤 4 中的图像 3,3
    • Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
    • When reassembling the Wi-Fi card, reattach the black wire closest to the screw and the gray wire on the other side of the black wire. With the WWAN card, reattach the blue wire on the left and the orange wire on the right.
    • There are also small color coded arrows on each card that match the corresponding wires, to make sure you connect to the correct spot.
  5. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 5 中的图像 3,3
    • Use the spudger to disconnect the LCD cable from the motherboard.
  6. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 6 中的图像 3,3
    • Disconnect the camera cable from the motherboard using a spudger.
  7. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 7 中的图像 2,2
    • Remove all antenna cables from their routing.
  8. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 8 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 8 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 8 中的图像 3,3
    • Using the Phillips #1 screwdriver, remove three 5 mm screws from the left hinge and three 5 mm screws from the right hinge.
  9. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 9 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 9 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 9 中的图像 3,3
    • Carefully rotate the hinges upward and remove the bottom of the machine from the LCD unit.
  10. Lenovo ThinkPad T480s Antenna Kit Replacement, LCD Bezel: 步骤 10 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement, LCD Bezel: 步骤 10 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement, LCD Bezel: 步骤 10 中的图像 3,3
    • Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
    • It is attached by adhesive so be careful not to break it. You may hear loud snaps when detaching the clips; this is normal.
  11. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 11 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 11 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 11 中的图像 3,3
    • Use the spudger to remove the internal bezel.
    • Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
    • Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
    • You will feel resistance and hear snapping as you remove the bezel because it is connected with clips. Be careful that you don't crack the bezel. The plastic is delicate in places.
  12. Lenovo ThinkPad T480s Antenna Kit Replacement, LCD Panel: 步骤 12 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement, LCD Panel: 步骤 12 中的图像 2,2
    • Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
  13. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 13 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 13 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 13 中的图像 3,3
    • Gently lift the panel and flip it over.
    • The panel is still connected to the unit by the LCD cable so be careful not to rip the connector when flipping it over.
  14. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 14 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 14 中的图像 2,2
    • Peel back the tape covering the LCD cable connector.
    • Use the spudger to unlock the LCD cable.
  15. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 15 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 15 中的图像 2,2
    • Remove the LCD cable from the socket.
  16. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 16 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 16 中的图像 2,2
    • Remove the LCD panel from the system.
  17. Lenovo ThinkPad T480s Antenna Kit Replacement, Hinges: 步骤 17 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement, Hinges: 步骤 17 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper right corner.
  18. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 18 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 18 中的图像 2,2
    • Remove the hinge in the upper right corner.
  19. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 19 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 19 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove two 2.8 mm screws from the hinge in the upper left corner.
  20. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 20 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 20 中的图像 2,2
    • Remove the hinge in the upper left corner.
  21. Lenovo ThinkPad T480s Antenna Kit Replacement, Antenna Kit: 步骤 21 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement, Antenna Kit: 步骤 21 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement, Antenna Kit: 步骤 21 中的图像 3,3
    • Pry the metallic tape and the black and blue antenna from the LCD Unit.
  22. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 22 中的图像 1,2 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 22 中的图像 2,2
    • Lift the black and blue cables from the routing.
  23. Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 23 中的图像 1,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 23 中的图像 2,3 Lenovo ThinkPad T480s Antenna Kit Replacement: 步骤 23 中的图像 3,3
    • Pry the metallic tape and the grey and orange antenna cables from the unit.
    • Lift the grey and orange antenna cables from the routing.
结论
Sarah Westberg
于03/11/19注册
23,354 声望
创作了70篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 74
总计 2,081
