跳转到主内容
Lenovo ThinkPad T480 LCD Screen Replacement
你所需要的
  1. Lenovo ThinkPad T480 LCD Screen Replacement, External Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad T480 LCD Screen Replacement, External Battery: 步骤 1 中的图像 2,2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 LCD Screen Replacement, Back Cover: 步骤 3 中的图像 1,2 Lenovo ThinkPad T480 LCD Screen Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 4 中的图像 3,3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 LCD Screen Replacement, Internal Battery: 步骤 5 中的图像 1,2 Lenovo ThinkPad T480 LCD Screen Replacement, Internal Battery: 步骤 5 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 6 中的图像 3,3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
  8. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Assembly: 步骤 8 中的图像 1,2 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Assembly: 步骤 8 中的图像 2,2
    • Remove the cables from the cable guides.
  9. Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 9 中的图像 1,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 9 中的图像 2,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Using the Phillips #1 screwdriver, remove two 4.3 mm screws from each hinge (four total).
  10. Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 10 中的图像 1,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 10 中的图像 2,3 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Lift the keyboard bezel up and slide it out from the hinges to separate it from the LCD assembly.
    • In this image, all of the internal components were removed prior to this step so your device will look somewhat different.
  11. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Bezel: 步骤 11 中的图像 1,2 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Bezel: 步骤 11 中的图像 2,2
    • Use the metal spudger to create a space between the bezel and lid and carefully undo the clips around the perimeter of the bezel.
  12. Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 12 中的图像 1,2 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Finish removing the bezel from the screen using the metal spudger and your hands.
    • The bottom edge of the bezel is not connected with clips but with adhesive. Take care as you remove it so you don't bend or break the bezel.
  13. Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: 步骤 13 中的图像 1,3 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: 步骤 13 中的图像 2,3 Lenovo ThinkPad T480 LCD Screen Replacement, LCD Screen: 步骤 13 中的图像 3,3
    • Remove the four 3.0 mm Phillips #1 screws from the four corners of the LCD screen.
    • Lift it up using the spudger and flip it over gently towards you.
    • The LCD screen is still connected by a connector cable so be sure not to yank or pull on the screen.
  14. Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 14 中的图像 1,2 Lenovo ThinkPad T480 LCD Screen Replacement: 步骤 14 中的图像 2,2
    • Using the black nylon spudger, disconnect the display connector cable and remove the LCD screen.
结论
3等其他人完成本指南。
Sarah Westberg
于03/11/19注册
35,272 声望
创作了71篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
10指南评论
For the screen replacement you really only need like 11 steps.
Step 1,2,9,10,12,35-40. All other steps are optional and it only took me 15 mins.
Batnert - 回复
Hello i was wondering how much did the screen cost you to buy?
wau bruh -
If the internal battery is disabled why do you need to remove it?
Dan Matiesanu - 回复
Hi Dan, if you disconnect the internal battery from the motherboard, (Step 12), you should be fine. We just want to make sure that there is no power to the system and the step to remove the battery is included as a precaution. Thanks!
Sarah Westberg -
@sarahw thank you but my question was more about why do you need to physically disconnect the battery if it is already disabled in BIOS?
Dan Matiesanu - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 79
过去 30 天: 380
总计 24,258
