跳转到主内容
Lenovo ThinkPad T480 Keyboard Replacement
你所需要的
  1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad T480 Keyboard Replacement, External Battery: 步骤 1 中的图像 2,2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Keyboard Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
  4. Lenovo ThinkPad T480 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Open the laptop so the keyboard is facing you.
  5. Lenovo ThinkPad T480 Keyboard Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
    • The keyboard is connected to the board by two ribbon connectors.
    • Be careful not to rip the connectors when you flip the keyboard over.
  6. Lenovo ThinkPad T480 Keyboard Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
    • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
  7. Lenovo ThinkPad T480 Keyboard Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
  8. Lenovo ThinkPad T480 Keyboard Replacement: 步骤 8 中的图像 1,2 Lenovo ThinkPad T480 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Remove the keyboard from the laptop.
结论
5等其他人完成本指南。
Sarah Westberg
于03/11/19注册
23,161 声望
创作了70篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,820篇指南
3条评论
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - 回复
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg -
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 119
过去 30 天: 515
总计 11,721
