跳转到主内容
Lenovo ThinkPad T480 Internal Battery Replacement
你所需要的
  1. Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: 步骤 1 中的图像 2,2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 2 中的图像 3,3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: 步骤 3 中的图像 1,2 Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 4 中的图像 3,3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: 步骤 5 中的图像 1,2 Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: 步骤 5 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
  6. Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 6 中的图像 3,3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad T480 Internal Battery Replacement: 步骤 7 中的图像 3,3
    • Using the black nylon spudger, wedge the battery up from the case and lift it out.
结论
7等其他人完成本指南。
Sarah Westberg
于03/11/19注册
23,155 声望
创作了70篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,818篇指南
4条评论
"What you need" contains a wrong part.
cumledomla - 回复
Hi @cumledomla, I've added the internal battery for this guide. Thanks for pointing that out! The external battery will show up in the "What you need" section because it's imported from the prerequisite guide for the external battery. Hope this helps.
Sarah Westberg - 回复
The "Battery 2" on my T480 does not load. Is Battery 2 the internal or the external battery?
Finn Hove - 回复
Battery 2 is the external battery.
Peter Falk - 回复
添加评论
浏览统计数据:
过去 24 小时: 40
过去 7 天: 287
过去 30 天: 1,158
总计 33,553
