跳转到主内容
Lenovo ThinkPad T480 Back Cover Replacement
你所需要的
  1. Lenovo ThinkPad T480 Back Cover Replacement, External Battery: 步骤 1 中的图像 1,2 Lenovo ThinkPad T480 Back Cover Replacement, External Battery: 步骤 1 中的图像 2,2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Back Cover Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T480 Back Cover Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T480 Back Cover Replacement: 步骤 2 中的图像 3,3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: 步骤 3 中的图像 1,2 Lenovo ThinkPad T480 Back Cover Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Back Cover Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T480 Back Cover Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T480 Back Cover Replacement: 步骤 4 中的图像 3,3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
结论
3等其他人完成本指南。
Sarah Westberg
于03/11/19注册
23,263 声望
创作了70篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,271篇指南
2条评论
Dont forget the 3 clips in the removable battery area. No one mentioned those and I ended up breaking a clip and cracking the bottom cover of my T480... :(
Neccros - 回复
Hey @neccros! Thanks for the feedback. I'm very sorry you cracked your bottom cover. I've updated the guide to incorporate your experience.
Sarah Westberg -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 54
过去 30 天: 230
总计 6,403
