跳转到主内容
Lenovo ThinkPad T470s Motherboard Replacement
你所需要的
  1. Lenovo ThinkPad T470s Motherboard Replacement, Bottom Panel: 步骤 1 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 步骤 2 中的图像 1,3 Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 步骤 2 中的图像 2,3 Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 步骤 2 中的图像 3,3
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
  3. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 3 中的图像 1,3 Lenovo ThinkPad T470s Motherboard Replacement: 步骤 3 中的图像 2,3 Lenovo ThinkPad T470s Motherboard Replacement: 步骤 3 中的图像 3,3
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
  4. Lenovo ThinkPad T470s Motherboard Replacement, Fan and Heat Sink: 步骤 4 中的图像 1,1
    • Loosen the four screws from the heatsink with a Phillips #000 screwdriver.
  5. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unplug the fan from the motherboard.
  6. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the heatsink and fan from the laptop.
  7. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 7 中的图像 1,1
    • Wipe off the old thermal paste with either 99% isopropyl alcohol or kimwipes.
  8. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 8 中的图像 1,2 Lenovo ThinkPad T470s Motherboard Replacement: 步骤 8 中的图像 2,2
  9. Lenovo ThinkPad T470s Motherboard Replacement, Wi-Fi Card: 步骤 9 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
    • The Wi-Fi card will lift to a slight angle after the screw is removed.
  10. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 10 中的图像 1,1
    • Grip the Wi-Fi card on both sides, then pull it directly out of its port.
  11. Lenovo ThinkPad T470s Motherboard Replacement, USB Board: 步骤 11 中的图像 1,2 Lenovo ThinkPad T470s Motherboard Replacement, USB Board: 步骤 11 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 3.3 mm screws.
  12. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 12 中的图像 1,1
    • Use your fingernail to flip up the gate, then pull the connector directly out of the port.
  13. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 13 中的图像 1,1
    • Lift the USB board up and out of the chassis.
  14. Lenovo ThinkPad T470s Motherboard Replacement, SSD: 步骤 14 中的图像 1,2 Lenovo ThinkPad T470s Motherboard Replacement, SSD: 步骤 14 中的图像 2,2
    • Locate the SSD slot between the large battery and fan.
    • Remove the screw securing the SSD using a Phillips #000 screwdriver.
  15. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 15 中的图像 1,2 Lenovo ThinkPad T470s Motherboard Replacement: 步骤 15 中的图像 2,2
    • Slide the SSD out of the motherboard.
  16. Lenovo ThinkPad T470s Motherboard Replacement, Motherboard: 步骤 16 中的图像 1,2 Lenovo ThinkPad T470s Motherboard Replacement, Motherboard: 步骤 16 中的图像 2,2
    • Flip up the locking gate, then pull the cable directly out of its port.
    • Use a Phillips #0 screwdriver to remove the single 3.3 mm screw on the top right corner of the motherboard.
  17. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove the single 3.3 mm screw with a Phillips #0 screwdriver.
  18. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 18 中的图像 1,1
  19. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 19 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw.
  20. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 20 中的图像 1,2 Lenovo ThinkPad T470s Motherboard Replacement: 步骤 20 中的图像 2,2
    • Disconnect the speaker connection covering the screw.
    • Use a Phillips #0 screwdriver to remove the single 5 mm screw securing the motherboard.
  21. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 21 中的图像 1,1
    • Remove the 3.3 mm screw using a Phillips #0 screwdriver.
  22. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 22 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the 3.3 mm screw.
  23. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 23 中的图像 1,1
  24. Lenovo ThinkPad T470s Motherboard Replacement: 步骤 24 中的图像 1,2 Lenovo ThinkPad T470s Motherboard Replacement: 步骤 24 中的图像 2,2
    • Gently grip the motherboard and slide it to the right to remove the USB ports from the chassis.
    • You will hear an audible clicking sound.
    • Lift the motherboard up and out of the chassis.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 108
总计 2,792
