跳转到主内容
Lenovo ThinkPad T470 SSD Replacement
你所需要的
  1. Lenovo ThinkPad T470 SSD Replacement, External Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad T470 SSD Replacement, External Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad T470 SSD Replacement, External Battery: 步骤 1 中的图像 3,3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 SSD Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T470 SSD Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T470 SSD Replacement: 步骤 2 中的图像 3,3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 SSD Replacement, Bottom Cover: 步骤 3 中的图像 1,2 Lenovo ThinkPad T470 SSD Replacement, Bottom Cover: 步骤 3 中的图像 2,2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 SSD Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T470 SSD Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T470 SSD Replacement: 步骤 4 中的图像 3,3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 SSD Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 SSD Replacement, SSD Assembly: 步骤 6 中的图像 1,2 Lenovo ThinkPad T470 SSD Replacement, SSD Assembly: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  7. Lenovo ThinkPad T470 SSD Replacement: 步骤 7 中的图像 1,2 Lenovo ThinkPad T470 SSD Replacement: 步骤 7 中的图像 2,2
    • Use the flat end of a spudger to separate the connector from its socket.
  8. Lenovo ThinkPad T470 SSD Replacement: 步骤 8 中的图像 1,3 Lenovo ThinkPad T470 SSD Replacement: 步骤 8 中的图像 2,3 Lenovo ThinkPad T470 SSD Replacement: 步骤 8 中的图像 3,3
    • Grab the tab on the left side of the SSD assembly, and pull up to remove it from the laptop.
  9. Lenovo ThinkPad T470 SSD Replacement, SSD: 步骤 9 中的图像 1,3 Lenovo ThinkPad T470 SSD Replacement, SSD: 步骤 9 中的图像 2,3 Lenovo ThinkPad T470 SSD Replacement, SSD: 步骤 9 中的图像 3,3
    • Use your fingers to detach the plastic bracket from the SSD assembly.
  10. Lenovo ThinkPad T470 SSD Replacement: 步骤 10 中的图像 1,2 Lenovo ThinkPad T470 SSD Replacement: 步骤 10 中的图像 2,2
    • Flip the SSD assembly over so that the green connector board is visible.
  11. Lenovo ThinkPad T470 SSD Replacement: 步骤 11 中的图像 1,2 Lenovo ThinkPad T470 SSD Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the metal bracket.
  12. Lenovo ThinkPad T470 SSD Replacement: 步骤 12 中的图像 1,3 Lenovo ThinkPad T470 SSD Replacement: 步骤 12 中的图像 2,3 Lenovo ThinkPad T470 SSD Replacement: 步骤 12 中的图像 3,3
    • Use your hands to lift the metal bracket up and away from the SSD assembly.
    • There may be some adhesive attaching the metal bracket to the SSD.
  13. Lenovo ThinkPad T470 SSD Replacement: 步骤 13 中的图像 1,1
    • Remove the single 4 mm screw using a Phillips #1 screwdriver.
  14. Lenovo ThinkPad T470 SSD Replacement: 步骤 14 中的图像 1,2 Lenovo ThinkPad T470 SSD Replacement: 步骤 14 中的图像 2,2
    • Use the flat end of a spudger to pry the SSD up slightly and pull it out of the slot with your other hand.
  15. Lenovo ThinkPad T470 SSD Replacement: 步骤 15 中的图像 1,2 Lenovo ThinkPad T470 SSD Replacement: 步骤 15 中的图像 2,2
    • Remove the two 4 mm screws from the SSD connector board using a Phillips #1 screwdriver.
  16. Lenovo ThinkPad T470 SSD Replacement: 步骤 16 中的图像 1,2 Lenovo ThinkPad T470 SSD Replacement: 步骤 16 中的图像 2,2
    • Use your hand to remove the SSD connector board from the metal enclosure.
结论
4等其他人完成本指南。
Kristen Gismondi
于11/12/14注册
100,201 声望
创作了258篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,758篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 108
过去 30 天: 419
总计 25,446
