简介
This guide will show you how to replace the internal battery in your Lenovo ThinkPad T470.
A healthy laptop battery will keep your laptop powered on, even when your device is unplugged from an external power source.
If your laptop no longer holds a charge, or loses its charge very quickly, you most likely have a dead or failing battery which may require replacement. Depending on the cause of your faulty battery, you may be able to resolve the issue using this list of troubleshooting symptoms and solutions from Lenovo’s support forum.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
你所需要的
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
Remove two 5 mm screws from the internal battery using a Phillips #1 screwdriver.
6等其他人完成本指南。
2条评论
Clear, concise and thoroughly enjoyed … thank you 🙏🏻
Nice. If you haven't broken your plastic pin on the upper side of external battery, it would be even better.
