跳转到主内容
Lenovo ThinkPad T470 Internal Battery Replacement
你所需要的
  1. Lenovo ThinkPad T470 Internal Battery Replacement, External Battery: 步骤 1 中的图像 1,3 Lenovo ThinkPad T470 Internal Battery Replacement, External Battery: 步骤 1 中的图像 2,3 Lenovo ThinkPad T470 Internal Battery Replacement, External Battery: 步骤 1 中的图像 3,3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 2 中的图像 1,3 Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 2 中的图像 2,3 Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 2 中的图像 3,3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Internal Battery Replacement, Bottom Cover: 步骤 3 中的图像 1,2 Lenovo ThinkPad T470 Internal Battery Replacement, Bottom Cover: 步骤 3 中的图像 2,2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 4 中的图像 1,3 Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 4 中的图像 2,3 Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 4 中的图像 3,3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 Internal Battery Replacement, Internal Battery: 步骤 6 中的图像 1,2 Lenovo ThinkPad T470 Internal Battery Replacement, Internal Battery: 步骤 6 中的图像 2,2
    • Remove two 5 mm screws from the internal battery using a Phillips #1 screwdriver.
  7. Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad T470 Internal Battery Replacement: 步骤 7 中的图像 3,3
    • Use your hands to lift the battery up and away from the laptop.
结论
6等其他人完成本指南。
Kristen Gismondi
于11/12/14注册
81,880 声望
创作了200篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,820篇指南
2条评论
Clear, concise and thoroughly enjoyed … thank you 🙏🏻
James Nickerson - 回复
Nice. If you haven't broken your plastic pin on the upper side of external battery, it would be even better.
Eldis Skenderagic - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 171
过去 30 天: 717
总计 18,302
