简介
Use this guide to replace the motherboard in your Lenovo ThinkPad T460 laptop.
The motherboard, also known as a system board or mainboard, is the primary printed circuit board (PCB) in a computer that enables communication between the internal components.
Diagnosing a faulty motherboard is tricky since the symptoms are similar to other failing components. Signs of a faulty motherboard may include overheating, error codes, the blue screen of death, or failure of other ports and components.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
你所需要的
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Use the pointed end of a spudger to pry the two rubber stoppers out of the battery compartment.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Use a pair of blunt nose tweezers to pull the black connector out of its socket.
Remove the single 3.7 mm screw from the left side of the hard drive using a Phillips #1 screwdriver.
一条评论
I used this guide to complete my first "iFixit" project - replacing the trackpad on my T460.
Wow, I was amazed at the quality of the instructions! The instructions and photos were very clear. In particular, I like the before and after photos for most steps. These make it so much clearer what direction you need to move something or make it simple to know where the screws are.
Thanks @kristen !
