简介
Follow this guide to replace the screen bezel on your Lenovo ThinkPad T16 Gen 3 laptop.
The Lenovo part number for the screen bezel with clips is 5CB1M21642. If your model doesn't have clips, the part number is 5CB1M21644 for models with the IR camera, 5CB1M21643 for the standard webcam, and 5CB1M21654 for no camera, only microphone. These parts also include the adhesive required for replacing the display.
If your bezel doesn't have clips, this guide can still be helpful, but it is recommended to be extra careful since the adhesive-only bezels are extremely fragile and designed to be consumed, not reused.
If you need to replace your whole screen, follow this guide instead.
你所需要的
Insert the tip of an opening pick at a downward angle between the bezel and screen assembly, near the top right corner.
Lower the pick so it's flat with the screen and the tip is under the screen bezel.
Gently lift the bezel on the right, top, and left sides to ensure all the clips are fully unfastened.
Once the adhesive is completely separated, lift the bottom edge of the bezel straight up to unfasten its clips.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
