跳转到主内容
Lenovo ThinkPad T16 Gen 3 SSD Replacement
你所需要的
  1. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 3,3
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Loosen the base cover screws: 步骤 2 中的图像 1,2 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Loosen the base cover screws: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Pry up the base cover: 步骤 3 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Pry up the base cover: 步骤 3 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Pry up the base cover: 步骤 3 中的图像 3,3
    • Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
    • Pry up the base cover until the clips unfasten.
  4. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the base cover: 步骤 4 中的图像 1,2 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the base cover: 步骤 4 中的图像 2,2
    • Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
    • Lift and remove the base cover.
    • During reassembly, lay the base cover into the frame, inserting it into the tabs along the battery edge. Press down firmly around the perimeter to reengage all the clips.
  5. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Loosen the battery screws: 步骤 5 中的图像 1,2 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Loosen the battery screws: 步骤 5 中的图像 2,2
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
  6. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the battery: 步骤 6 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the battery: 步骤 6 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the battery: 步骤 6 中的图像 3,3
    • Lift the edge of the battery with the connector to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
    • Remove the battery
    • During reassembly:
    • Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
    • Lower the battery into place so the connector goes over its socket.
  7. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the SSD screw: 步骤 7 中的图像 1,2 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the SSD screw: 步骤 7 中的图像 2,2
    • Use a Phillips screwdriver to remove the 4 mm‑long screw securing the SSD to the motherboard.
  8. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the SSD: 步骤 8 中的图像 1,3 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the SSD: 步骤 8 中的图像 2,3 Lenovo ThinkPad T16 Gen 3 SSD Replacement, Remove the SSD: 步骤 8 中的图像 3,3
    • Use your fingernail or the flat end of a spudger to lift the edge of the SSD with a screw notch enough to grip it with your fingers.
    • Use your fingers to pull the SSD straight out of its socket and remove it.
  9. Lenovo ThinkPad T16 Gen 3 SSD Replacement, Reassembly information: 步骤 9 中的图像 1,1
    • Check the condition of the thermal pad under the SSD and replace it if damaged. It is 20 x 65 mm and 0.5 mm thick, and the Lenovo part number is 02DL836. If the pad remained intact but is stuck to the bottom of the old SSD, carefully transfer it to its spot on the board.
    • Even if you remove the pad, this laptop is not compatible with double-sided SSDs. Some of them may fit, but the ones we've tested do not.
    • Carefully put the new pad onto the board, making sure it goes into the white rectangle beneath the SSD.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove thermal pad backings from the new part before you install it.
Nick Schultz
于03/24/24注册
37,787 声望
创作了226篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,787篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 87
总计 1,456
