跳转到主内容
Lenovo ThinkPad T15 Gen 2 SSD Replacement
你所需要的
  1. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • If your device has a nano‑SIM card tray on the back edge, remove it before starting your repair.
    • Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
  2. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the front clips: 步骤 3 中的图像 1,3 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the front clips: 步骤 3 中的图像 2,3 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the front clips: 步骤 3 中的图像 3,3
    • Angle the pick down at about 30 degrees.
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the USB clip: 步骤 4 中的图像 1,2 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Release the USB clip: 步骤 4 中的图像 2,2
    • Insert an opening tool between the lower case and the chassis, just to the right of the USB port on the left edge.
    • Pry the opening case up to release the clip next to the USB port.
    • It may take significant force and multiple attempts to release the clip. You will hear a popping noise when the clip releases.
  5. Lenovo ThinkPad T15 Gen 2 SSD Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad T15 Gen 2 SSD Replacement: 步骤 5 中的图像 2,2
    • Insert an opening pick on the left edge above the USB port. Slide the pick all the way up to the ethernet port to release the clips.
  6. Lenovo ThinkPad T15 Gen 2 SSD Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad T15 Gen 2 SSD Replacement: 步骤 6 中的图像 2,2
    • Insert an opening pick on the right edge near the corner.
    • Slide the pick along the right edge all the way to the HDMI port to release the rest of the clips.
  7. Lenovo ThinkPad T15 Gen 2 SSD Replacement: 步骤 7 中的图像 1,3 Lenovo ThinkPad T15 Gen 2 SSD Replacement: 步骤 7 中的图像 2,3 Lenovo ThinkPad T15 Gen 2 SSD Replacement: 步骤 7 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  8. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Disconnect the battery: 步骤 8 中的图像 1,3 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Disconnect the battery: 步骤 8 中的图像 2,3 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Disconnect the battery: 步骤 8 中的图像 3,3
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
  9. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Unfasten the SSD: 步骤 9 中的图像 1,2 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Unfasten the SSD: 步骤 9 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3.5 mm screw securing the SSD.
  10. Lenovo ThinkPad T15 Gen 2 SSD Replacement, Remove the SSD: 步骤 10 中的图像 1,3 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Remove the SSD: 步骤 10 中的图像 2,3 Lenovo ThinkPad T15 Gen 2 SSD Replacement, Remove the SSD: 步骤 10 中的图像 3,3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
结论
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad T Series answers community for help.
另外一个人完成了本指南。
Spencer Day
于09/14/22注册
155,036 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,781篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 37
过去 30 天: 161
总计 3,139
