你所需要的
这个步骤还没有翻译 帮忙翻译一下
First, flip the laptop upside down. Underneath, you will see a few compartments that can be unscrewed.
Before doing any unscrewing, though, you'll want to remove the battery (just in case)
First, push the battery lock to the right
As the battery lock is as far to the right as it can go, pull the battery out, in the direction of the two arrows
这个步骤还没有翻译 帮忙翻译一下
Now that the battery is out, we can start the rest of the teardown.
First, unscrew the six screws circled. The one circled in orange is just a little lower and harder to see
Next, take a tool like the Opening Pick and slide it in, then move it around the highlighted area to pop the panel off
这个步骤还没有翻译 帮忙翻译一下
Removing this panel gives us access to the processor, graphics, RAM, HDD, and fan/heatsink
Processor: Intel Core 2 Duo T6570
Graphics: Intel 82GM45 Graphics and Memory Controller Hub
HDD (Hard Drive): *This model can vary, depending on if this part was replaced or not
The hard drive in my model has a Seagate Momentus 250GB 5400RPM drive
RAM: *This model can vary, depending on if this part was replaced or not
这个步骤还没有翻译 帮忙翻译一下
These steps are optional too, but I will remove these parts solely because this is a complete teardown.
The remaining two panels both have one screw that needs to be unscrewed before the panels can be lifted up. (These screws also stick in the panel, so no need to worry about them falling out!)
Unscrew this screw with your screwdriver - but be careful! This screw DOES come out all the way, so if you are not careful, it may roll away.
Once the screw is out, the disk drive can be pulled out.
这个步骤还没有翻译 帮忙翻译一下
First, you'll want to disconnect the ribbon cable for the keyboard/trackpad keys
After that, you will want to take off the two screws holding down the keyboard. There is also a ribbon cable hooked up to it that must be disconnected.
There is some adhesive under the area marked, so it may take a little more force than usual to lift.
这个步骤还没有翻译 帮忙翻译一下
When I got to this step, I only found one screw holding the motherboard, which I found to be extremely odd...
I did find threaded holes at the places indicated with a box, so there may be some here.
There are also two cables connected here. The one on top of the motherboard being the connector to the rear USB port. The one underneath is the cable that connects to the charging port.
这个步骤还没有翻译 帮忙翻译一下
On the left side of the display, there are two screws holding in the left hinge.
On the right side, there are also two screws holding in the right hinge
Aaaand behind the laptop there are two screws, one on the right and left side.
At this point, the display can be lifted up out of the chassis.
这个步骤还没有翻译 帮忙翻译一下
There are three rubber pieces that are stuck on with adhesive that need to be removed. They can be removed with anything small and thin enough to get under them.
Under the rubber, there are screws that need to be unscrewed.
After that, take a opening pick and insert it at an angle shown in the second picture.
Repeat the last two steps (three if this one is included) as many times as needed until the bezel is removed.
这个步骤还没有翻译 帮忙翻译一下
The hinges are connected to a frame that the display is screwed into, so they must be taken out (the display, frame, and hinges will come out in one part). There are two screws (one on each hinge) holding them in
Before lifting the display out, the webcam must be disconnected. Find the connector and pull the cable out in the direction shown.
There are also two screws holding the webcam assembly in place
At this point, the display can be lifted right out.
2条评论
Lenovos are always a pain to gut/repair. Probably because they’re military grade…
Yea it stinks to have to tear one open.
They’re military grade? With my personal experience with a few different models, I wouldn’t think the military would WANT to use them..
