你所需要的
Start at the microSD slot. This is the easiest entry point.
Use the opening pick gently to slide underneath the back cover of the tablet.
Slide the opening pick around the entire edge of the tablet. Don't force it and work slowly to release all clips.
Once all clips are loose, lift and remove the back cover.
在这个步骤中使用的工具:Tweezers$4.99
There is a yellow tape holding the microSD card reader connector. Use tweezers to hold down the tape.
Gently lift the tab on the microSD card reader's ZIF connector, and gently pull the ribbon cable free.
Use a spudger to lift the rear camera press-fit connector up and free.
Use tweezers to lift the rear camera out of the frame.
Using tweezers, lift the yellow tape hiding the front camera.
Disconnect the front camera's connector from the motherboard using tweezers.
Use tweezers to pull screen digitizer cable from the motherboard.
4等其他人完成本指南。
