跳转到主内容
Lenovo Tab 4 TB-8504F Motherboard Replacement
你所需要的
  1. Lenovo Tab 4 TB-8504F Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo Tab 4 TB-8504F Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo Tab 4 TB-8504F Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Start at the microSD slot.
    • Use the opening pick to slide underneath the back cover of the tablet.
    • Slide the opening pick around the tablet until the back cover is off.
  2. Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 2 中的图像 1,3 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 2 中的图像 2,3 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the 8 screws with a Phillips #000 screwdriver [bit].
    • There is a screw under the blue "s" sticker.
    • Remove tape holding plate down.
    • Use precision tweezers or your fingers to remove plate.
  3. Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 3 中的图像 1,2 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove yellow tape.
    • Use a spudger or plastic opening tool to remove the battery's ribbon cable from the motherboard.
  4. Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 4 中的图像 1,3 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 4 中的图像 2,3 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 4 中的图像 3,3
    • Gently pull on the two stretch release adhesive strips. Do not pull up, pull away from battery.
    • Once the tabs are off, lift the battery up from the frame.
    • Do not bend or puncture the battery.
  5. Lenovo Tab 4 TB-8504F Motherboard Replacement, MicroSD Card Reader: 步骤 5 中的图像 1,2 Lenovo Tab 4 TB-8504F Motherboard Replacement, MicroSD Card Reader: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • There is a yellow tape holding the microSD card reader connector. Use tweezers to hold down the tape.
    • Gently lift the tab on the microSD card reader's ZIF connector, and gently pull the ribbon cable free.
  6. Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 6 中的图像 1,2 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 6 中的图像 2,2
    • Lift the microSD card reader with tweezers or your fingers.
  7. Lenovo Tab 4 TB-8504F Motherboard Replacement, Rear Camera: 步骤 7 中的图像 1,2 Lenovo Tab 4 TB-8504F Motherboard Replacement, Rear Camera: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a spudger to lift the rear camera press-fit connector up and free.
    • Use tweezers to lift the rear camera out of the frame.
  8. Lenovo Tab 4 TB-8504F Motherboard Replacement, Front Camera: 步骤 8 中的图像 1,2 Lenovo Tab 4 TB-8504F Motherboard Replacement, Front Camera: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, lift the yellow tape hiding the front camera.
    • Disconnect the front camera's connector from the motherboard using tweezers.
  9. Lenovo Tab 4 TB-8504F Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 Lenovo Tab 4 TB-8504F Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to pull screen digitizer cable from the motherboard.
  10. Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 10 中的图像 1,1
    • Desolder the two top speaker wires from the motherboard.
    • Be careful as the soldering iron is hot! Improper handling can result in severe burns.
  11. Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 11 中的图像 1,3 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 11 中的图像 2,3 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 11 中的图像 3,3
    • Desolder the black and red speaker wires from the motherboard.
  12. Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 12 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove the two screws that secure the speaker to the motherboard.
  13. Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 13 中的图像 1,2 Lenovo Tab 4 TB-8504F Motherboard Replacement: 步骤 13 中的图像 2,2
    • Lift motherboard from the tablet.
    • Using your hand, you can separate the top speaker from the motherboard.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 47
总计 3,899
