简介
Use this guide to replace or upgrade the RAM in your Lenovo Legion Y7000P laptop.
This laptop has two slots for DDR4 2666 MHz memory.
你所需要的
Use a Phillips screwdriver to remove the 11 screws securing the back cover:
Five 11.5 mm‑long screws
Six 4.7 mm-long screws
Insert the flat side of an opening pick between the top right corner of the back cover and frame.
Slide the opening pick down the right edge and around the bottom right corner to release the clips.
Slide the two tabs near the center of the back cover's top edge under the hinge cover.
Press down firmly around the perimeter of the back cover to engage all the clips.
A stiff, black cover runs across the heatsink and fans.
Heat an iOpener and apply it to the cover for two minutes.
Use the flat end of a spudger to push the battery connector straight out of its socket.
Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
Remove the stick of RAM.
Repeat the process to remove the other stick of RAM.
Check your repair by running hardware tests with Lenovo Diagnostics.
