跳转到主内容
Lenovo Legion 5 15ACH6H Left SSD Replacement
你所需要的
  1. Lenovo Legion 5 15ACH6H Left SSD Replacement, Back cover removal: 步骤 1 中的图像 1,2 Lenovo Legion 5 15ACH6H Left SSD Replacement, Back cover removal: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.5 mm PH1 screws
    • Four 4.7 mm PH1 screws
  2. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the front clips: 步骤 2 中的图像 1,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the front clips: 步骤 2 中的图像 2,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the front clips: 步骤 2 中的图像 3,3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 3 中的图像 1,3 Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 3 中的图像 2,3 Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 3 中的图像 3,3
    • Angle the pick to about 30˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left clips: 步骤 4 中的图像 1,2 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left clips: 步骤 4 中的图像 2,2
    • Insert the edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the left edge to release the clips.
  5. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right clips: 步骤 5 中的图像 1,2 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right clips: 步骤 5 中的图像 2,2
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right vent clips: 步骤 6 中的图像 1,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right vent clips: 步骤 6 中的图像 2,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the right vent clips: 步骤 6 中的图像 3,3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 7 中的图像 1,2 Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 7 中的图像 2,2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left vent clips: 步骤 8 中的图像 1,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left vent clips: 步骤 8 中的图像 2,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Release the left vent clips: 步骤 8 中的图像 3,3
    • Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
  9. Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 9 中的图像 1,2 Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 9 中的图像 2,2
  10. Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the back cover: 步骤 10 中的图像 1,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the back cover: 步骤 10 中的图像 2,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the back cover: 步骤 10 中的图像 3,3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  11. Lenovo Legion 5 15ACH6H Left SSD Replacement, Disconnect the battery: 步骤 11 中的图像 1,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Disconnect the battery: 步骤 11 中的图像 2,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Disconnect the battery: 步骤 11 中的图像 3,3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  12. Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 12 中的图像 1,2 Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 12 中的图像 2,2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  13. Lenovo Legion 5 15ACH6H Left SSD Replacement, Left SSD removal: 步骤 13 中的图像 1,2 Lenovo Legion 5 15ACH6H Left SSD Replacement, Left SSD removal: 步骤 13 中的图像 2,2
    • Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the left SSD shield to the motherboard.
    • During reassembly, make sure the hole near the top screw aligns with the post on the motherboard.
  14. Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the SSD shield: 步骤 14 中的图像 1,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the SSD shield: 步骤 14 中的图像 2,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the SSD shield: 步骤 14 中的图像 3,3
    • Grab the SSD shield and lift up to remove it.
  15. Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 15 中的图像 1,2 Lenovo Legion 5 15ACH6H Left SSD Replacement: 步骤 15 中的图像 2,2
    • Use a Phillips screwdriver to remove the 2.7 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  16. Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the left SSD: 步骤 16 中的图像 1,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the left SSD: 步骤 16 中的图像 2,3 Lenovo Legion 5 15ACH6H Left SSD Replacement, Remove the left SSD: 步骤 16 中的图像 3,3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
7等其他人完成本指南。
Chayton Ritter
于08/21/20注册
22,531 声望
创作了105篇指南
团队
Guide Team Guide Team 的会员
Staff
9 名成员
创作了11,485篇指南
1指南评论
sorry guys, I'm new to all this and I don't understand, exactly the same heatsink on the right side of the laptop what is it, is this really the second connector for the m2 PCI 3.0 x 4 ssd connector.
Pls help me
Albert XYZ - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 70
过去 30 天: 362
总计 13,232
