跳转到主内容
Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement
你所需要的
  1. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the 10 screws securing the lower case:
    • Six 12 mm screws
    • Four 4.5 mm screws
  2. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: 步骤 3 中的图像 1,3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: 步骤 3 中的图像 2,3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Release the clips: 步骤 3 中的图像 3,3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Continue sliding the opening pick along the left and right edges to release the remaining clips.
  4. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: 步骤 4 中的图像 1,3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: 步骤 4 中的图像 2,3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the lower case: 步骤 4 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: 步骤 5 中的图像 1,3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: 步骤 5 中的图像 2,3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Disconnect the battery: 步骤 5 中的图像 3,3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  6. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the right SSD: 步骤 6 中的图像 1,2 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Unfasten the right SSD: 步骤 6 中的图像 2,2
    • Use a Phillips screwdriver to remove the 2.4 mm screw securing the right SSD.
  7. Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: 步骤 7 中的图像 1,3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: 步骤 7 中的图像 2,3 Lenovo Ideapad Gaming 3 15ACH6 Right SSD Replacement, Remove the SSD: 步骤 7 中的图像 3,3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
Spencer Day
于09/14/22注册
54,914 声望
创作了407篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,299篇指南
4条评论
Hello u said the wrong m.2 size its not M.2 2230 SSD its a m.2 2242
Matthew Dhanraj - 回复
Thanks for the article... So the right ssd is M.2 2242 NVME
mfarhanfp - 回复
what type of SSD is that?
Gloabl - 回复
Hi! As stated in the introduction, this is an M.2 2242 SSD.
Spencer Day -
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 58
过去 30 天: 278
总计 5,558
