跳转到主内容
Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement
你所需要的
  1. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement, Heat Sink: 步骤 1 中的图像 1,1
    • Flip the Lenova ideapad onto its back and remove the screws using a screwdriver with a PH0 bit. All screws will use this bit.
    • 8 (5.35mm long screws)
    • 2 (15.37mm long screws)
    • 1 (5.63mm long screw)
  2. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Firmly pull the cover off and locate the screws circled in red. These screws will stay attached to the old heat sink.
    • Loosen each screw until an audible click can be heard. The screws do not need to be fully removed from the old heat sink.
  3. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: 步骤 3 中的图像 1,1
    • Carefully grab the heat sink and lift it straight up. This is to prevent spreading thermal paste.
  4. Lenovo IdeaPad Y700-15ACZ Heat Sink Replacement: 步骤 4 中的图像 1,1
结论
With all steps completed test the Lenova Ideapad to ensure it is properly working. It is recommended to run intensive applications while monitoring internal temperatures. This will show if the cooling system is properly working.
Blake Ludge
于03/28/23注册
109 声望
撰写一个指南
团队
IUPUI, Team 3-1, Harley Spring 2023 IUPUI, Team 3-1, Harley Spring 2023 的会员
IUPUI-HARLEY-S23S3G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 144
