跳转到主内容
Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement
你所需要的
  1. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: 步骤 3 中的图像 1,3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: 步骤 3 中的图像 2,3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement, Cooling Fans: 步骤 3 中的图像 3,3
    • Remove the six 3.5 mm screws that secure the fans in place using a Phillips #00 screwdriver.
    • Loosen the seven captive screws using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to unwind the black and gray wires from the clips that are holding them onto the left side fan.
  5. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 5 中的图像 2,2
    • Lift the black piece of cloth tape that secures the right side fan wires to the circuit board.
  6. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 6 中的图像 1,3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 6 中的图像 2,3 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 6 中的图像 3,3
    • Use tweezers to unplug the wiring connectors that are connected to each fan.
  7. Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad Flex 6-14IKB Cooling Fans Replacement: 步骤 7 中的图像 2,2
    • Gently remove the fans from the laptop.
    • There is thermal paste attaching the ducting of the fans that will require some careful prying.
    • When replacing the fan, reapply a pea sized amount of thermal paste to the fan ducts.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 16
总计 471
