跳转到主内容
Lenovo IdeaPad 3-15IIL05 SSD Replacement
你所需要的
  1. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the back cover: 步骤 2 中的图像 1,2 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the back cover: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: 步骤 4 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: 步骤 4 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: 步骤 4 中的图像 3,3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: 步骤 5 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: 步骤 5 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: 步骤 5 中的图像 3,3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: 步骤 6 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: 步骤 6 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: 步骤 6 中的图像 3,3
    • Slide the opening pick to the top right corner to release the right clips.
  7. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: 步骤 7 中的图像 1,2 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: 步骤 7 中的图像 2,2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: 步骤 8 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: 步骤 8 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: 步骤 8 中的图像 3,3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: 步骤 9 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: 步骤 9 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: 步骤 9 中的图像 3,3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: 步骤 10 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: 步骤 10 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: 步骤 10 中的图像 3,3
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
  11. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: 步骤 11 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: 步骤 11 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: 步骤 11 中的图像 3,3
    • A delicate thermal pad covers the SSD. If you're planning on reusing it, be extra careful during this step.
    • Gently lift the left edge of the thermal pad.
    • Carefully slide the flat end of a spudger back and forth under the pad while slowly peeling the pad back.
    • Remove the thermal pad.
    • Set the thermal pad aside and apply it to the new SSD during reassembly.
    • If you tore the thermal pad when taking it off, don’t worry—you can still reuse it.
  12. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the SSD: 步骤 12 中的图像 1,2 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the SSD: 步骤 12 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3 mm-long screw securing the SSD.
    • The SSD will pop up at a slight angle with the screw removed.
  13. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: 步骤 13 中的图像 1,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: 步骤 13 中的图像 2,3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: 步骤 13 中的图像 3,3
    • Pull the SSD out of its socket and remove it.
    • During reassembly, insert the SSD at a slight downward angle into its socket.
结论
Check your repair by running hardware tests with Lenovo Diagnostics.
2等其他人完成本指南。
Spencer Day
于09/14/22注册
155,120 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,788篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 117
过去 30 天: 429
总计 9,804
