跳转到主内容
Lenovo IdeaPad 100s-14IBR Battery Replacement
你所需要的
  1. Lenovo IdeaPad 100s-14IBR Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the eight 4mm PH00 screws.
    • Remove the four 2mm PH00 screws.
  2. Lenovo IdeaPad 100s-14IBR Battery Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 100s-14IBR Battery Replacement: 步骤 2 中的图像 2,2
    • Use the nylon spudger to loosen the back cover from the back of the device.
    • You may hear a bit of a snapping sound, but this is normal.
  3. Lenovo IdeaPad 100s-14IBR Battery Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad 100s-14IBR Battery Replacement: 步骤 3 中的图像 2,2
    • Remove six 4mm Phillips #00 screws.
    • Pull the battery connector parallel to the motherboard to disconnect the battery from the motherboard.
  4. Lenovo IdeaPad 100s-14IBR Battery Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad 100s-14IBR Battery Replacement: 步骤 4 中的图像 2,2
    • Use a nylon spudger to pry the battery up and out of the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 31
总计 4,137
