跳转到主内容
Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement
你所需要的
  1. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Flip the device over and lay it down with the underside facing upwards.
  2. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 步骤 2 中的图像 1,2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 步骤 2 中的图像 2,2
    • Remove the ten screws with a Phillips #00 screwdriver.
  3. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, make your way around the edge of the laptop.
  4. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 步骤 4 中的图像 1,2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 步骤 4 中的图像 2,2
    • After making sure the back panel is completely free from the body, remove the back panel.
  5. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: 步骤 5 中的图像 1,3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: 步骤 5 中的图像 2,3 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement, Auxiliary and USB Port: 步骤 5 中的图像 3,3
    • Disconnect the ribbon connector using the iFixit opening tool tool by flipping up the black flap and pulling the ribbon out.
  6. Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 步骤 6 中的图像 1,2 Lenovo Flex 6-11IGM Auxiliary and USB Port Replacement: 步骤 6 中的图像 2,2
    • Take the three 3.5mm silver screws out using the Phillips #00 screwdriver.
    • Remove the protective silver shield before removing the ports.
    • Using the iFixit opening tool, insert its end underneath the ports, and pull them upwards toward you to remove them safely.
结论
另外一个人完成了本指南。
Rie Kuraoka
于01/23/20注册
886 声望
创作了7篇指南
团队
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 的会员
CPSU-PATON-S20S7G10
2 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 370
