简介
This guide will show you how to replace your motherboard in your Lenovo 100s Chromebook-11IBY. Use this guide if your Lenovo 100s Chromebook-11IBY motherboard breaks down. Symptoms of a faulty motherboard include the device not turning on and frequent crashes.
你所需要的
Using the black nylon spudger, lift up the grey bar of the ZIF connector attached to the motherboard located in the bottom right corner.
Pull out the ribbon cable connecting the motherboard to the daughterboard.
即将完成!
结论
