跳转到主内容
LeapFrog Scribble and Write Speaker Replacement
你所需要的
  1. LeapFrog Scribble and Write Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Turn your toy over so that the back is facing upward.
  2. LeapFrog Scribble and Write Speaker Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #00 screwdriver, unscrew all circled areas.
  3. LeapFrog Scribble and Write Speaker Replacement: 步骤 3 中的图像 1,1
    • Very carefully, remove the back case to reveal the contents of the toy.
  4. LeapFrog Scribble and Write Speaker Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the screw highlighted in the image.
  5. LeapFrog Scribble and Write Speaker Replacement: 步骤 5 中的图像 1,1
    • Un-solder the wiring from the speaker and motherboard.
    • Caution: Be careful when using a soldering iron. Improper usage may result in burns.
结论
Anthony Kidd
于02/10/16注册
256 声望
创作了2篇指南
团队
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 的会员
USFT-NANCE-S16S1G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 728
