跳转到主内容
LeapFrog LeapPad2 Explorer Front Cover Replacement
你所需要的
  1. LeapFrog LeapPad2 Explorer Front Cover Replacement, Battery: 步骤 1 中的图像 1,2 LeapFrog LeapPad2 Explorer Front Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 2 中的图像 1,3 LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 2 中的图像 2,3 LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 2 中的图像 3,3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Front Cover Replacement, Back Cover: 步骤 3 中的图像 1,2 LeapFrog LeapPad2 Explorer Front Cover Replacement, Back Cover: 步骤 3 中的图像 2,2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 4 中的图像 1,3 LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 4 中的图像 2,3 LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 4 中的图像 3,3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
  5. LeapFrog LeapPad2 Explorer Front Cover Replacement, Front Cover: 步骤 5 中的图像 1,2 LeapFrog LeapPad2 Explorer Front Cover Replacement, Front Cover: 步骤 5 中的图像 2,2
    • Remove the following screws securing the front cover to the main device:
    • Three 6.0 mm Phillips screws
    • Three 7.0 mm Phillips screws
    • Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
    • The white plastic component holding the speaker must be removed to reach the third 7.0 mm Phillips screw. Refer to Step 2.
  6. LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 6 中的图像 1,2 LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 6 中的图像 2,2
    • Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
  7. LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 7 中的图像 1,2 LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 7 中的图像 2,2
    • When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge.
    • Use tweezers to remove the piece.
    • In case the piece falls out unexpectedly, refer to this step to make sure you put this piece back in place during the reassembly of your device.
  8. LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 8 中的图像 1,2 LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 8 中的图像 2,2
    • Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected.
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • For proper soldering and desoldering techniques reference 如何焊接和拆焊.
    • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed.
    • Be extremely careful with the cables in this step as they could melt, burn, or break.
  9. LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 9 中的图像 1,2 LeapFrog LeapPad2 Explorer Front Cover Replacement: 步骤 9 中的图像 2,2
    • Pry the power cables from the device using your fingers or tweezers.
    • Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
结论
Nupur Garg
于04/12/14注册
867 声望
创作了7篇指南
团队
Cal Poly, Team 8-10, Regan Spring 2014 Cal Poly, Team 8-10, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G10
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 1,511
