跳转到主内容
Le Pan S Speaker Replacement
你所需要的
  1. Le Pan S Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Le Pan S Speaker Replacement: 步骤 2 中的图像 1,2 Le Pan S Speaker Replacement: 步骤 2 中的图像 2,2
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Le Pan S Speaker Replacement: 步骤 3 中的图像 1,1
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  4. Le Pan S Speaker Replacement: 步骤 4 中的图像 1,2 Le Pan S Speaker Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
  5. Le Pan S Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Remove the four 3.5 mm Phillips #00 screws holding the speakers in place.
    • Move the speakers out of the way.
  6. Le Pan S Speaker Replacement: 步骤 6 中的图像 1,1
    • Place the wick on the solder connecting the speakers to the electrical board.
    • Place a heated soldering iron on the solder wick to melt the existing solder.
    • Pull the speakers off of the solder connection.
    • A solder vacuum can also be used in place of solder wick to remove old solder.
    • If you need more help with the soldering process, take a look at iFixit's guide for soldering and desoldering connections.
结论
Maria Dole
于09/17/15注册
395 声望
创作了3篇指南
团队
IUPUI, Team 2-1, Harley Fall 2015 IUPUI, Team 2-1, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S2G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 210
