跳转到主内容
加入维修社区 - 创建账户
LG VX6100 Main Display Replacement
你所需要的
  1. LG VX6100 Main Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Open the battery casing by pressing the gray "PUSH" button. Slide the back of the casing downward.
    询问修复机器人
    添加评论
    • Carefully remove the faulty battery from the back of the phone.
    • Inspect the battery port to ensure the battery is the issue. Ensure the four gold connecting prongs are intact and are pointing straight into the port.
    询问修复机器人
    添加评论
  2. LG VX6100 Main Display Replacement: 步骤 3 中的图像 1,1
    • Align the gold prongs with the gold plates on the bottom of the battery. Make sure "This Side Up" is visible
    • Push the battery flat against the back of the phone until it clicks into place.
    询问修复机器人
    添加评论
    • Replace the back cover of the phone by sliding the casing down into place. Gently press the top until it clicks.
    • Charge the device and turn it on to confirm the issue is resolved.
    询问修复机器人
    添加评论
  3. LG VX6100 Main Display Replacement, Front Case: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the four grey plugs using either tweezers or a push pin.
    询问修复机器人
    添加评论
  4. LG VX6100 Main Display Replacement: 步骤 6 中的图像 1,1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
    询问修复机器人
    添加评论
  5. LG VX6100 Main Display Replacement: 步骤 7 中的图像 1,1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
    询问修复机器人
    添加评论
  6. LG VX6100 Main Display Replacement: 步骤 8 中的图像 1,1
    • The case can now be removed and the interior of the front is accessible.
    询问修复机器人
    添加评论
  7. LG VX6100 Main Display Replacement, Main Display: 步骤 9 中的图像 1,2 LG VX6100 Main Display Replacement, Main Display: 步骤 9 中的图像 2,2
    • Locate the solder on the side of the metal plate on the top half of the phone.
    • Place a piece of solder wick on top of the solder.
    • To desolder the connection, very carefully place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • The soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat this step if any solder remains.
    询问修复机器人
    添加评论
  8. LG VX6100 Main Display Replacement: 步骤 10 中的图像 1,1
    • After the solder has been removed, pry off the camera assembly connection shield with the plastic opening tool.
    询问修复机器人
    添加评论
  9. LG VX6100 Main Display Replacement: 步骤 11 中的图像 1,2 LG VX6100 Main Display Replacement: 步骤 11 中的图像 2,2
    • Remove the main display by lifting up the extruded white edge with your fingernail.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Ryan Bishop
于04/17/12注册
1 声望
创作了3篇指南
团队
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012 的会员
CPSU-REGAN-S12S12G39
3 名成员
创作了32篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 33
总计 1,521
