当前版本的文档还未经巡查,您可以查看最新的已查核版本。
When removing back cover, be careful not to break the speaker wires.
Using an Opening Tool, carefully pry off the back cover.
Using tweezers, gently pull the speaker wires out.
DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
Use a soldering iron to desolder the solder joint on the front of the motherboard.
If you need more information on soldering, refer to this guide.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
