跳转到主内容
LG VX4500 Motherboard Replacement
你所需要的
  1. LG VX4500 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Motherboard Replacement: 步骤 2 中的图像 1,2 LG VX4500 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Motherboard Replacement, Rear Cover: 步骤 3 中的图像 1,1
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 Motherboard Replacement: 步骤 5 中的图像 1,3 LG VX4500 Motherboard Replacement: 步骤 5 中的图像 2,3 LG VX4500 Motherboard Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Separate the two halves.
  7. LG VX4500 Motherboard Replacement, Keypad: 步骤 7 中的图像 1,3 LG VX4500 Motherboard Replacement, Keypad: 步骤 7 中的图像 2,3 LG VX4500 Motherboard Replacement, Keypad: 步骤 7 中的图像 3,3
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  8. LG VX4500 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Carefully flip the logic board up and out of the way.
  9. LG VX4500 Motherboard Replacement: 步骤 9 中的图像 1,3 LG VX4500 Motherboard Replacement: 步骤 9 中的图像 2,3 LG VX4500 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
  10. LG VX4500 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • Use a soldering iron to desolder the solder joint on the front of the motherboard.
    • If you need more information on soldering, refer to this guide.
  11. LG VX4500 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Desolder the joint on the back using a soldering iron.
  12. LG VX4500 Motherboard Replacement: 步骤 12 中的图像 1,3 LG VX4500 Motherboard Replacement: 步骤 12 中的图像 2,3 LG VX4500 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Carefully detach the ribbon cable and remove the motherboard.
结论
David Foster
于04/11/10注册
1 声望
创作了8篇指南
团队
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G88
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,571
