跳转到主内容
LG VX4500 display interconnect cable
你所需要的
  1. LG VX4500 display interconnect cable, Battery: 步骤 1 中的图像 1,1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 display interconnect cable: 步骤 2 中的图像 1,2 LG VX4500 display interconnect cable: 步骤 2 中的图像 2,2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 display interconnect cable, Rear Cover: 步骤 3 中的图像 1,1
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 display interconnect cable: 步骤 4 中的图像 1,1
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 display interconnect cable: 步骤 5 中的图像 1,3 LG VX4500 display interconnect cable: 步骤 5 中的图像 2,3 LG VX4500 display interconnect cable: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 display interconnect cable: 步骤 6 中的图像 1,1
    • Separate the two halves.
  7. LG VX4500 display interconnect cable, Keypad: 步骤 7 中的图像 1,3 LG VX4500 display interconnect cable, Keypad: 步骤 7 中的图像 2,3 LG VX4500 display interconnect cable, Keypad: 步骤 7 中的图像 3,3
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  8. LG VX4500 display interconnect cable: 步骤 8 中的图像 1,1
    • Carefully flip the logic board up and out of the way.
  9. LG VX4500 display interconnect cable: 步骤 9 中的图像 1,3 LG VX4500 display interconnect cable: 步骤 9 中的图像 2,3 LG VX4500 display interconnect cable: 步骤 9 中的图像 3,3
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
  10. LG VX4500 display interconnect cable, Motherboard: 步骤 10 中的图像 1,1
    • DO NOT TOUCH SOLDERING IRON. IT IS EXTREMELY HOT.
    • Use a soldering iron to desolder the solder joint on the front of the motherboard.
    • If you need more information on soldering, refer to this guide.
  11. LG VX4500 display interconnect cable: 步骤 11 中的图像 1,1
    • Desolder the joint on the back using a soldering iron.
  12. LG VX4500 display interconnect cable: 步骤 12 中的图像 1,3 LG VX4500 display interconnect cable: 步骤 12 中的图像 2,3 LG VX4500 display interconnect cable: 步骤 12 中的图像 3,3
    • Carefully detach the ribbon cable and remove the motherboard.
  13. LG VX4500 display interconnect cable, Outer Display Cover: 步骤 13 中的图像 1,1
    • Remove 4 rubber grommets using the Spudger.
  14. LG VX4500 display interconnect cable: 步骤 14 中的图像 1,1
    • Remove 4 screws using the Phillips #00 Screwdriver.
  15. LG VX4500 display interconnect cable: 步骤 15 中的图像 1,3 LG VX4500 display interconnect cable: 步骤 15 中的图像 2,3 LG VX4500 display interconnect cable: 步骤 15 中的图像 3,3
    • Carefully pry off outer cover using iPod Opening Tool.
  16. LG VX4500 display interconnect cable, Display: 步骤 16 中的图像 1,2 LG VX4500 display interconnect cable, Display: 步骤 16 中的图像 2,2
    • Remove speaker using the Spudger.
  17. LG VX4500 display interconnect cable: 步骤 17 中的图像 1,2 LG VX4500 display interconnect cable: 步骤 17 中的图像 2,2
    • Remove vibrator using the Spudger.
  18. LG VX4500 display interconnect cable: 步骤 18 中的图像 1,2 LG VX4500 display interconnect cable: 步骤 18 中的图像 2,2
    • Lift up LCD display using iPod Opening Tool.
  19. LG VX4500 display interconnect cable: 步骤 19 中的图像 1,1
    • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
    • De-solder solder joint using Soldering Iron.
  20. LG VX4500 display interconnect cable: 步骤 20 中的图像 1,2 LG VX4500 display interconnect cable: 步骤 20 中的图像 2,2
    • Pry off ribbon cable using iPod Opening Tool.
  21. LG VX4500 display interconnect cable, Ribbon Cable: 步骤 21 中的图像 1,3 LG VX4500 display interconnect cable, Ribbon Cable: 步骤 21 中的图像 2,3 LG VX4500 display interconnect cable, Ribbon Cable: 步骤 21 中的图像 3,3
    • Turn phone so that the back side is facing you.
    • Press blue button and remove top half using Spudger.
  22. LG VX4500 display interconnect cable: 步骤 22 中的图像 1,2 LG VX4500 display interconnect cable: 步骤 22 中的图像 2,2
    • Remove cable from bottom section.
结论
David Foster
于04/11/10注册
1 声望
创作了8篇指南
团队
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G88
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 3,200
