跳转到主内容
LG V50 ThinQ Motherboard Replacement
你所需要的
  1. LG V50 ThinQ Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 LG V50 ThinQ Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 LG V50 ThinQ Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Flip the phone over, so that the back of the phone is facing you.
    • Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
  2. LG V50 ThinQ Motherboard Replacement: 步骤 2 中的图像 1,3 LG V50 ThinQ Motherboard Replacement: 步骤 2 中的图像 2,3 LG V50 ThinQ Motherboard Replacement: 步骤 2 中的图像 3,3
    • With the back side open, unscrew all the 1 mm Phillips #000 screws.
    • Remember to keep the screws in a safe place for reassembly later!
  3. LG V50 ThinQ Motherboard Replacement: 步骤 3 中的图像 1,3 LG V50 ThinQ Motherboard Replacement: 步骤 3 中的图像 2,3 LG V50 ThinQ Motherboard Replacement: 步骤 3 中的图像 3,3
    • Take out the two brackets that are covering the internal components.
  4. LG V50 ThinQ Motherboard Replacement: 步骤 4 中的图像 1,3 LG V50 ThinQ Motherboard Replacement: 步骤 4 中的图像 2,3 LG V50 ThinQ Motherboard Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
    • Pull up with tweezers on the dark orange cable to disconnect it.
  5. LG V50 ThinQ Motherboard Replacement: 步骤 5 中的图像 1,3 LG V50 ThinQ Motherboard Replacement: 步骤 5 中的图像 2,3 LG V50 ThinQ Motherboard Replacement: 步骤 5 中的图像 3,3
    • Disconnect the orange cable by pulling the connector piece up with your fingers
    • Pull up with tweezers on the end of the white wire to disconnect it from the motherboard
    • Using the metal spudger, pull up from below the motherboard at the top of the phone and near the battery to remove the motherboard from the phone.
结论
Tanmay Sonawane
于10/30/23注册
262 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 的会员
UMASSD-GULBRANDSEN-F23S2G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 31
总计 142
