跳转到主内容
LG V30 Battery Replacement
你所需要的
视频概述
LG V30 Battery Repair Guide
  1. LG V30 Battery Replacement, Power Off: 步骤 1 中的图像 1,3 LG V30 Battery Replacement, Power Off: 步骤 1 中的图像 2,3 LG V30 Battery Replacement, Power Off: 步骤 1 中的图像 3,3
    • Drain the battery's charge below 25%.
    • Power off the phone by pressing and holding the Power/Lock key on the backside of the phone for three seconds. Tap the Power Off option and Power Off to confirm.
  2. LG V30 Battery Replacement, Remove SIM Tray/Card: 步骤 2 中的图像 1,3 LG V30 Battery Replacement, Remove SIM Tray/Card: 步骤 2 中的图像 2,3 LG V30 Battery Replacement, Remove SIM Tray/Card: 步骤 2 中的图像 3,3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  3. LG V30 Battery Replacement, Heat Backing's Adhesive: 步骤 3 中的图像 1,1
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. See the iOpener instructions guide to learn how to use an iOpener.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. LG V30 Battery Replacement: 步骤 4 中的图像 1,3 LG V30 Battery Replacement: 步骤 4 中的图像 2,3 LG V30 Battery Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Use a suction cup to lift up the back cover up.
    • Insert the edge of a plastic card into the space created between the cover and frame.
  5. LG V30 Battery Replacement: 步骤 5 中的图像 1,3 LG V30 Battery Replacement: 步骤 5 中的图像 2,3 LG V30 Battery Replacement: 步骤 5 中的图像 3,3
    • Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
  6. LG V30 Battery Replacement: 步骤 6 中的图像 1,3 LG V30 Battery Replacement: 步骤 6 中的图像 2,3 LG V30 Battery Replacement: 步骤 6 中的图像 3,3
    • Continue to slide the cards around the remaining three edges to release the adhesive.
  7. LG V30 Battery Replacement, Remove Back Cover: 步骤 7 中的图像 1,3 LG V30 Battery Replacement, Remove Back Cover: 步骤 7 中的图像 2,3 LG V30 Battery Replacement, Remove Back Cover: 步骤 7 中的图像 3,3
    • Carefully remove the back cover, making sure that the adhesive is sliced through on all sides.
    • Because this phone's backing is attached using adhesive, you will need to replace the adhesive when re-assembling the phone.
  8. LG V30 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the ten Phillips #000 screws from the midframe.
  9. LG V30 Battery Replacement: 步骤 9 中的图像 1,3 LG V30 Battery Replacement: 步骤 9 中的图像 2,3 LG V30 Battery Replacement: 步骤 9 中的图像 3,3
    • Using a plastic spudger, pry up the midframe of the phone.
  10. LG V30 Battery Replacement, Remove Midframe: 步骤 10 中的图像 1,2 LG V30 Battery Replacement, Remove Midframe: 步骤 10 中的图像 2,2
    • Carefully pull the midframe from the rest of the phone's body.
    • The midframe is connected to the main body with a small slot on the right side of the midframe. Carefully free the frame from this slot by gently wiggling and pulling outwards at the same time.
  11. LG V30 Battery Replacement: 步骤 11 中的图像 1,3 LG V30 Battery Replacement: 步骤 11 中的图像 2,3 LG V30 Battery Replacement: 步骤 11 中的图像 3,3
    • Use the plastic spudger to pry up the four press-fit connectors on the top portion of the motherboard.
  12. LG V30 Battery Replacement, Remove Speaker Assembly: 步骤 12 中的图像 1,3 LG V30 Battery Replacement, Remove Speaker Assembly: 步骤 12 中的图像 2,3 LG V30 Battery Replacement, Remove Speaker Assembly: 步骤 12 中的图像 3,3
    • Pry up the speaker panel with a plastic spudger and remove it from the phone.
  13. LG V30 Battery Replacement: 步骤 13 中的图像 1,1
    • Use a heat gun to apply heat to the front face of the phone. This will soften the adhesive used to secure the phone's battery.
    • When using a heat gun or hair dryer to soften the adhesive, be careful not to overheat the battery. The hair dryer/heat gun will make the phone hot to the touch, so handle the phone with care.
    • Alternatively, you can place a heated iOpener across the top of the battery for approximately three minutes to soften the adhesive holding the battery to the device.
    • If you have multiple iOpeners, it is recommended to also put one on the screen side of the battery.
  14. LG V30 Battery Replacement: 步骤 14 中的图像 1,3 LG V30 Battery Replacement: 步骤 14 中的图像 2,3 LG V30 Battery Replacement: 步骤 14 中的图像 3,3
    • Insert a plastic card at the bottom edge of the battery
    • Gently work the plastic card around the left side of the battery, separating the battery from its adhesive.
    OF NOTE: there is a display flex which is easily torn if you position even a plastic tool under the battery incorrectly. It is located to the bottom-right of the device.
    Alexander Owen - 回复
  15. LG V30 Battery Replacement, Remove Battery: 步骤 15 中的图像 1,3 LG V30 Battery Replacement, Remove Battery: 步骤 15 中的图像 2,3 LG V30 Battery Replacement, Remove Battery: 步骤 15 中的图像 3,3
    • Use the plastic card to pry the battery upwards from its slot.
    • Use your fingers to lift the battery away from the phone.
    • Because this battery is attached using adhesive, you will need to replace the adhesive when installing a new battery.
结论
To reassemble your device, follow these instructions in reverse order. After installing a new battery, run down its charge completely. Then, charge the battery fully. This will calibrate the new battery. Then, use the phone normally.
11等其他人完成本指南。
Witrigs
于11/24/15注册
69,454 声望
创作了378篇指南
12条评论
Do you have to put the adhesive for the battery?
RT RT - 回复
Suction cups on both sides, heatgun on the back pannel, then lift. Much easier. And you don't have to worry about breaking the back panel.
DJ Somebody - 回复
Why can’t the idiots at LG, or indeed any other company, make a phone with an MQA capable DAC, and a replaceable battery?
tonywinter - 回复
it is not about idiocy. When you do not conform to a set battery shape you can configure the insides of a phone for more performance and features. That being said the LG V30 does have a standard battery shape. So in this case it is a desire to create built in obsolescence. After all it is believed in the western world cell phone sales are flat.
Malinourn Malinourn -
And..as long as the battery is in the phone it can be used to track you…
Loud Harley - 回复
amen brother!!! #truth
steve -
I agree however most people are on their phones all day or most of the day so why would they turn them off or wanna take the battery out?
Jesse -
The built in obsolescence is having the opposite effect by having me not want to upgrade from my V20. The captive batteries of every single new phone makes me reluctant.
ag1wrvi02 - 回复
So, I’ve done a few iphone battery replacements…I understand patience/heating…following directions.
Well, of course, the back glass broke (2X) during removal. I’m using a card, as instructed. so I finally work the back off, and the power button/fingerprint gizmo separated from the back/stayed attached to the little pad where it fits on the frame. I’m terrified to move it, as I don’t know exactly where it’s got to line up on the back glass….but I can’t get the phone apart w/out removing it.
THEN I notice that somehow that I had cut the ribbon cable that goes to the coil for wireless charging/google pay/file share. WTH? DON’T go in too deep THERE with the card…I trimmed the place where it tore, to make sure the thin foil wasn’t shorted together, and put a piece of thin plastic as an insulator under it.
So, I get it back together as well as I can, but 2/3 of the adhesive was so messed up, (balled up) I had to pick it off, otherwise the back won’t seat against the frame. The finger print reader doesn’t work now.
McGyver9 - 回复
Ran out of room….
So, #1, I couldn’t find a ‘new’ adhesive for the back…(by itself)…I would recommend it, if you can find it…maybe even a new back glass
I’m hoping that the fingerprint reader disc coming off of the power button is why it’s no longer working? Any others experience this? I checked the contacts…I think I put it back/centered correctly.
I’m considering dropping the $30 for a new back assembly…..
I’m REALLY going to miss my fingerprint reader, for logging in to bank accounts etc….
Any suggestions?
Thanks in advance,
Chris
McGyver9 -
Ask yourself; Why do empires like LG, Samsung, Apple/so on make it so difficult to remove batteries?
Jesse - 回复
Grrr, because they must want to motivate women, moms, people on the autism spectrum and environmentalists to learn how to teach themselves microsoldering, electronic and appliance repair, and get involved in activism to create laws to prevent them from making all of us go into a self inflicted death spiral of empty materialism. I have had enough! Also, because they must really not care about how difficult it is to mine rare earth metals and like the challenge of who can destroy the planet 1st. That is why I think they make them hard to remove, even if they don't know it yet.
N. Watson -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 56
过去 30 天: 219
总计 27,490
