跳转到主内容
LG Refrigerator Water Inlet Valve Assembly Test and Replacement
你所需要的
  1. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Unfasten the condenser cover: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the screws securing the condenser cover to the rear of the refrigerator.
  3. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Remove the condenser cover: 步骤 3 中的图像 1,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Remove the condenser cover: 步骤 3 中的图像 2,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Remove the condenser cover: 步骤 3 中的图像 3,3
    • Tilt the top edge of the condenser cover toward you.
    • Lift and remove the condenser cover.
  4. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Disconnect the water inlet valve assembly: 步骤 4 中的图像 1,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Disconnect the water inlet valve assembly: 步骤 4 中的图像 2,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Disconnect the water inlet valve assembly: 步骤 4 中的图像 3,3
    • Squeeze and pull down the connectors for the valve assembly harness to disconnect them.
  5. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Reposition the water inlet valve assembly: 步骤 5 中的图像 1,1
    • Use a Phillips screwdriver to remove the screw(s) securing the water inlet valve assembly.
  6. LG Refrigerator Water Inlet Valve Assembly Test and Replacement: 步骤 6 中的图像 1,2 LG Refrigerator Water Inlet Valve Assembly Test and Replacement: 步骤 6 中的图像 2,2
    • Pull the water inlet valve assembly out of the refrigerator for better access to electrical connections and water tubing connections.
    • Don't try to remove the inlet valve assembly completely because it is still attached by tubes and wires.
  7. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Disconnect the remaining electrical connection(s): 步骤 7 中的图像 1,2 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Disconnect the remaining electrical connection(s): 步骤 7 中的图像 2,2
    • Squeeze and pull downward the remaining water inlet valve assembly connector(s) to disconnect it.
  8. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Disconnect the water tubing connections: 步骤 8 中的图像 1,2 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Disconnect the water tubing connections: 步骤 8 中的图像 2,2
    • Use long nose pliers to pull and remove the locking clip from a tubing connector.
  9. LG Refrigerator Water Inlet Valve Assembly Test and Replacement: 步骤 9 中的图像 1,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement: 步骤 9 中的图像 2,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement: 步骤 9 中的图像 3,3
    • Use your fingers to squeeze the flange surrounding the water tube toward the valve to release the tube.
    • While you squeeze the flange, pull the tubing straight out of the connector.
  10. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Remove the inlet valve assembly: 步骤 10 中的图像 1,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Remove the inlet valve assembly: 步骤 10 中的图像 2,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Remove the inlet valve assembly: 步骤 10 中的图像 3,3
    • Repeat this procedure for the remaining tubes.
    • Remove the inlet valve assembly.
  11. LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Test the inlet valve assembly: 步骤 11 中的图像 1,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Test the inlet valve assembly: 步骤 11 中的图像 2,3 LG Refrigerator Water Inlet Valve Assembly Test and Replacement, Test the inlet valve assembly: 步骤 11 中的图像 3,3
    • If you have a multimeter, you can use it to test the inlet valve assembly components.
    • Set the multimeter to the ohm (Ω) setting.
    • For the first solenoid, test the resistance between the wires from it at the connector.
    • The acceptable resistance is 360 to 420 Ω.
    • Repeat the test on the connector for the other solenoid.
    • To test the flow meter, test the resistance between the wires from it at the connector.
    • The acceptable resistance is 4 kΩ to 30 kΩ.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
于06/30/22注册
38,497 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,608篇指南
1指南评论
Just turn off the power for 30 seconds and check it again.
Gene Bodel - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 96
过去 30 天: 331
总计 5,212
