简介
Use this guide to test and replace the water dispensing switch on your LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The water dispensing switch triggers a solenoid valve in the refrigerator so that it dispenses chilled water through the dispenser.
If the switch fails, the refrigerator will either not dispense water or won't stop dispensing water.
The repair is moderately difficult. The removal of the dispensing unit is probably the most challenging step.
你所需要的
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
To remove the left door handle, first open the right door.
Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
Right side clips
Top clips
Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
Use a spudger to pry out the top edge of the dispenser assembly.
Once you've created a gap, use your fingertips to pull the edge downward.
Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
Grasp the top edge of the dispenser assembly in the middle and pull outwards.
Continue prying and pulling around the perimeter of the assembly to release it.
Squeeze the multiple wire connectors and pull them straight off to disconnect them from the various PC boards.
Some of the connectors may be permanently attached to the PC board and can't be removed.
Use a Phillips screwdriver to remove the screw securing the circuit board holder to the dispenser assembly. Many, but not all, units will have this PC board and holder.
Lift and remove the circuit board holder from the dispenser assembly.
Use a Phillips screwdriver to remove screws securing the water switch bracket to the dispenser assembly.
Slide the water dispensing switch off of its pegs on the bracket.
Pull the connector straight off the water dispensing switch to disconnect it.
Touch one probe to each of the switch terminals at the same time.
If the switch does not operate as described above, replace it.
