简介
Use this guide to replace the refrigerator compartment light in an LG Refrigerator. The process involves removing the light unit, disconnecting it, and installing a new one. This guide is for LED based units.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
你所需要的
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Lift up the front edge of the shelf to release it.
Unhook the shelf and remove it.
Repeat the last two steps for each shelf you wish to remove.
Use a Phillips screwdriver to remove the screws that secure the light unit.
With both hands, pull down the front edge of the light unit until it pops free.
Pinch the light unit connector to release it and pull it out straight to disconnect.
Remove the light unit.
Use a spudger to pry and release the two clips on the rear edge of the light.
Use a Philips head driver to remove the screws securing the light module.
