跳转到主内容
LG Refrigerator Control Board Replacement
你所需要的
  1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Control Board Replacement, Unfasten the control board cover: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  3. LG Refrigerator Control Board Replacement, Remove the control board cover: 步骤 3 中的图像 1,3 LG Refrigerator Control Board Replacement, Remove the control board cover: 步骤 3 中的图像 2,3 LG Refrigerator Control Board Replacement, Remove the control board cover: 步骤 3 中的图像 3,3
    • Tilt the top edge of the cover toward you and lift it off.
  4. LG Refrigerator Control Board Replacement, Disconnect the control board: 步骤 4 中的图像 1,3 LG Refrigerator Control Board Replacement, Disconnect the control board: 步骤 4 中的图像 2,3 LG Refrigerator Control Board Replacement, Disconnect the control board: 步骤 4 中的图像 3,3
    • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
    • Squeeze and pull the connectors to disconnect them from the control board.
    • Make sure to fully reconnect each connector when reassembling.
  5. LG Refrigerator Control Board Replacement, Release the control board: 步骤 5 中的图像 1,3 LG Refrigerator Control Board Replacement, Release the control board: 步骤 5 中的图像 2,3 LG Refrigerator Control Board Replacement, Release the control board: 步骤 5 中的图像 3,3
    • Use your thumb to pry up and release the top left retaining clip securing the control board.
    • With your other hand, pull the top left corner of the control board out to loosen it.
  6. LG Refrigerator Control Board Replacement: 步骤 6 中的图像 1,3 LG Refrigerator Control Board Replacement: 步骤 6 中的图像 2,3 LG Refrigerator Control Board Replacement: 步骤 6 中的图像 3,3
    • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
  7. LG Refrigerator Control Board Replacement, Remove the control board: 步骤 7 中的图像 1,1
    • Lift the control board out by its edges and remove it.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
3等其他人完成本指南。
Bill Gilbert
于06/30/22注册
38,494 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,589篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 139
总计 3,450
