跳转到主内容
LG Phoenix 2 Charge Port Replacement
你所需要的
  1. LG Phoenix 2 Charge Port Replacement, Battery: 步骤 1 中的图像 1,3 LG Phoenix 2 Charge Port Replacement, Battery: 步骤 1 中的图像 2,3 LG Phoenix 2 Charge Port Replacement, Battery: 步骤 1 中的图像 3,3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Charge Port Replacement: 步骤 2 中的图像 1,3 LG Phoenix 2 Charge Port Replacement: 步骤 2 中的图像 2,3 LG Phoenix 2 Charge Port Replacement: 步骤 2 中的图像 3,3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Charge Port Replacement, Motherboard: 步骤 3 中的图像 1,2 LG Phoenix 2 Charge Port Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
  4. LG Phoenix 2 Charge Port Replacement: 步骤 4 中的图像 1,2 LG Phoenix 2 Charge Port Replacement: 步骤 4 中的图像 2,2
    • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
  5. LG Phoenix 2 Charge Port Replacement: 步骤 5 中的图像 1,3 LG Phoenix 2 Charge Port Replacement: 步骤 5 中的图像 2,3 LG Phoenix 2 Charge Port Replacement: 步骤 5 中的图像 3,3
    • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
  6. LG Phoenix 2 Charge Port Replacement: 步骤 6 中的图像 1,3 LG Phoenix 2 Charge Port Replacement: 步骤 6 中的图像 2,3 LG Phoenix 2 Charge Port Replacement: 步骤 6 中的图像 3,3
    • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
  7. LG Phoenix 2 Charge Port Replacement, Charge Port: 步骤 7 中的图像 1,2 LG Phoenix 2 Charge Port Replacement, Charge Port: 步骤 7 中的图像 2,2
  8. LG Phoenix 2 Charge Port Replacement: 步骤 8 中的图像 1,3 LG Phoenix 2 Charge Port Replacement: 步骤 8 中的图像 2,3 LG Phoenix 2 Charge Port Replacement: 步骤 8 中的图像 3,3
    • Desolder the USB port from the motherboard and remove it from the device.
结论
3等其他人完成本指南。
Alex Selsley
于11/04/19注册
325 声望
创作了2篇指南
团队
IUPUI, Team S1-G1, Harley Fall 2019 IUPUI, Team S1-G1, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S1G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 686
