跳转到主内容
LG G8 ThinQ Headphone Jack Replacement
你所需要的
  1. LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: 步骤 1 中的图像 1,3 LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: 步骤 1 中的图像 2,3 LG G8 ThinQ Headphone Jack Replacement, SIM Card Tray: 步骤 1 中的图像 3,3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Headphone Jack Replacement, Back Panel: 步骤 2 中的图像 1,3 LG G8 ThinQ Headphone Jack Replacement, Back Panel: 步骤 2 中的图像 2,3 LG G8 ThinQ Headphone Jack Replacement, Back Panel: 步骤 2 中的图像 3,3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Headphone Jack Replacement, Midframe: 步骤 3 中的图像 1,3 LG G8 ThinQ Headphone Jack Replacement, Midframe: 步骤 3 中的图像 2,3 LG G8 ThinQ Headphone Jack Replacement, Midframe: 步骤 3 中的图像 3,3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Headphone Jack Replacement, Speaker System: 步骤 4 中的图像 1,3 LG G8 ThinQ Headphone Jack Replacement, Speaker System: 步骤 4 中的图像 2,3 LG G8 ThinQ Headphone Jack Replacement, Speaker System: 步骤 4 中的图像 3,3
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: 步骤 5 中的图像 1,3 LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: 步骤 5 中的图像 2,3 LG G8 ThinQ Headphone Jack Replacement, Headphone Jack: 步骤 5 中的图像 3,3
    • Using an opening tool, carefully disconnect the ribbon cable connecting the 3.5mm audio jack to the motherboard.
    • Remove the screw holding the 3.5 mm audio jack in place using a Phillips #000 screwdriver.
    • Remove the audio jack from the phone.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 22
总计 967
