跳转到主内容
加入维修社区 - 创建账户
LG G Pad 8.3 Volume Control Buttons Replacement
你所需要的
  1. LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: 步骤 1 中的图像 1,2 LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: 步骤 1 中的图像 2,2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
    询问修复机器人
    添加评论
  2. LG G Pad 8.3 Volume Control Buttons Replacement: 步骤 2 中的图像 1,3 LG G Pad 8.3 Volume Control Buttons Replacement: 步骤 2 中的图像 2,3 LG G Pad 8.3 Volume Control Buttons Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
    添加评论
  3. LG G Pad 8.3 Volume Control Buttons Replacement: 步骤 3 中的图像 1,2 LG G Pad 8.3 Volume Control Buttons Replacement: 步骤 3 中的图像 2,2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
    询问修复机器人
    添加评论
  4. LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: 步骤 4 中的图像 1,2 LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: 步骤 4 中的图像 2,2
    • With the screen facing towards you and the top of the tablet towards your left, locate the volume buttons on the left side.
    • Using a spudger or your hands, remove the volume control buttons, which are attached with adhesive.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
CSU Fullerton, Team 1-6, Bruce Fall 2015 CSU Fullerton, Team 1-6, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G6
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 39
总计 1,486
