跳转到主内容
LG G Pad 8.3 Speaker Replacement
你所需要的
  1. LG G Pad 8.3 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,2 LG G Pad 8.3 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Speaker Replacement: 步骤 2 中的图像 1,3 LG G Pad 8.3 Speaker Replacement: 步骤 2 中的图像 2,3 LG G Pad 8.3 Speaker Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Speaker Replacement: 步骤 3 中的图像 1,2 LG G Pad 8.3 Speaker Replacement: 步骤 3 中的图像 2,2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 LG G Pad 8.3 Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $16.96
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  5. LG G Pad 8.3 Speaker Replacement: 步骤 5 中的图像 1,1
    • Use your fingers to remove the speaker.
结论
4等其他人完成本指南。
Mario Salguero
于09/14/15注册
781 声望
创作了6篇指南
团队
CSU Fullerton, Team 1-6, Bruce Fall 2015 CSU Fullerton, Team 1-6, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G6
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,713
