简介
If your tablet isn't working properly, you may need to replace the motherboard. This guide will show you how to replace the motherboard.
你所需要的
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
结论
8等其他人完成本指南。
