跳转到主内容
加入维修社区 - 创建账户
LG G Pad 8.3 Front Facing Camera Replacement
你所需要的
  1. LG G Pad 8.3 Front Facing Camera Replacement, Back Panel: 步骤 1 中的图像 1,2 LG G Pad 8.3 Front Facing Camera Replacement, Back Panel: 步骤 1 中的图像 2,2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
    询问修复机器人
  2. LG G Pad 8.3 Front Facing Camera Replacement: 步骤 2 中的图像 1,3 LG G Pad 8.3 Front Facing Camera Replacement: 步骤 2 中的图像 2,3 LG G Pad 8.3 Front Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Front Facing Camera Replacement: 步骤 3 中的图像 1,2 LG G Pad 8.3 Front Facing Camera Replacement: 步骤 3 中的图像 2,2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
    询问修复机器人
  4. LG G Pad 8.3 Front Facing Camera Replacement, Speaker: 步骤 4 中的图像 1,2 LG G Pad 8.3 Front Facing Camera Replacement, Speaker: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  5. LG G Pad 8.3 Front Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Use your fingers to remove the speaker.
  6. LG G Pad 8.3 Front Facing Camera Replacement, Battery: 步骤 6 中的图像 1,2 LG G Pad 8.3 Front Facing Camera Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the 3mm Phillips #000 screws from the corners of the battery.
    询问修复机器人
  7. LG G Pad 8.3 Front Facing Camera Replacement: 步骤 7 中的图像 1,3 LG G Pad 8.3 Front Facing Camera Replacement: 步骤 7 中的图像 2,3 LG G Pad 8.3 Front Facing Camera Replacement: 步骤 7 中的图像 3,3
    • Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
    • The cable is attached with an adhesive.
    • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    询问修复机器人
  8. LG G Pad 8.3 Front Facing Camera Replacement: 步骤 8 中的图像 1,2 LG G Pad 8.3 Front Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
    • Remove the ribbon cable from the device.
    询问修复机器人
  9. LG G Pad 8.3 Front Facing Camera Replacement: 步骤 9 中的图像 1,2 LG G Pad 8.3 Front Facing Camera Replacement: 步骤 9 中的图像 2,2
    • Unhook the battery from the top of the device.
  10. LG G Pad 8.3 Front Facing Camera Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Unhook the small yellow ribbon on top of the motherboard.
    询问修复机器人
  11. LG G Pad 8.3 Front Facing Camera Replacement: 步骤 11 中的图像 1,1
    • Remove all the 3mm silver screws and the 2mm black screws on the motherboard and carefully lift it out of the device.
    询问修复机器人
  12. LG G Pad 8.3 Front Facing Camera Replacement: 步骤 12 中的图像 1,2 LG G Pad 8.3 Front Facing Camera Replacement: 步骤 12 中的图像 2,2
    • Use a plastic opening tool to lift the motherboard out of the device.
    询问修复机器人
  13. LG G Pad 8.3 Front Facing Camera Replacement, Front Facing Camera: 步骤 13 中的图像 1,2 LG G Pad 8.3 Front Facing Camera Replacement, Front Facing Camera: 步骤 13 中的图像 2,2
    • Use a plastic opening tool to lift the front facing camera out of the device.
    询问修复机器人
结论
另外一个人完成了本指南。
团队
CSU Fullerton, Team 1-6, Bruce Fall 2015 CSU Fullerton, Team 1-6, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G6
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 53
总计 1,929
