当前版本的文档还未经巡查,您可以查看最新的已查核版本。
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back panel.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
After using the plastic opening tools, pry the device open with your hands.
Remove the back panel from the screen.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
