跳转到主内容
LG Front Load Washing Machine Main Board Replacement
你所需要的
  1. LG Front Load Washing Machine Main Board Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Main Board Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Main Board Replacement, Remove the top panel: 步骤 3 中的图像 1,2 LG Front Load Washing Machine Main Board Replacement, Remove the top panel: 步骤 3 中的图像 2,2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Main Board Replacement: 步骤 4 中的图像 1,2 LG Front Load Washing Machine Main Board Replacement: 步骤 4 中的图像 2,2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: 步骤 5 中的图像 1,2 LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: 步骤 5 中的图像 2,2
    • Depending on your device, your pressure sensor might have a wire harness. If so, disconnect each wire on the harness.
    • Disconnect the connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG Front Load Washing Machine Main Board Replacement: 步骤 6 中的图像 1,2 LG Front Load Washing Machine Main Board Replacement: 步骤 6 中的图像 2,2
    • Disconnect the hose from the pressure sensor.
  7. LG Front Load Washing Machine Main Board Replacement, Unfasten the pressure sensor: 步骤 7 中的图像 1,1
    • Remove the screw(s) securing the pressure sensor.
  8. LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: 步骤 8 中的图像 1,3 LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: 步骤 8 中的图像 2,3 LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: 步骤 8 中的图像 3,3
    • Unclip the pressure sensor from the chassis or other components.
  9. LG Front Load Washing Machine Main Board Replacement: 步骤 9 中的图像 1,2 LG Front Load Washing Machine Main Board Replacement: 步骤 9 中的图像 2,2
    • Lift the pressure sensor away chassis and remove it.
  10. LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: 步骤 10 中的图像 1,3 LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: 步骤 10 中的图像 2,3 LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: 步骤 10 中的图像 3,3
    • Disconnect any cables or fasteners secured to the control panel cover.
    • Repeat this procedure for any bundled cables that keep the cover from opening.
  11. LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: 步骤 11 中的图像 1,3 LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: 步骤 11 中的图像 2,3 LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: 步骤 11 中的图像 3,3
    • Use a flathead screwdriver or a prying tool, to unclip the main board cover.
    • Remove the main board cover.
  12. LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: 步骤 12 中的图像 1,2 LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: 步骤 12 中的图像 2,2
    • Remove the screw(s) securing the main board to the back side of the washer.
  13. LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: 步骤 13 中的图像 1,3 LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: 步骤 13 中的图像 2,3 LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: 步骤 13 中的图像 3,3
    • Slide the main board out of its slot in the chassis.
  14. LG Front Load Washing Machine Main Board Replacement, Remove the main board: 步骤 14 中的图像 1,3 LG Front Load Washing Machine Main Board Replacement, Remove the main board: 步骤 14 中的图像 2,3 LG Front Load Washing Machine Main Board Replacement, Remove the main board: 步骤 14 中的图像 3,3
    • Label each connector and its spot on the main board. During reassembly, reattach each connector to its proper spot.
    • Lift the main board out of the chassis to access each of the connectors.
    • Disconnect each connector from the main board.
    • Remove the main board.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
Bill Gilbert
于06/30/22注册
38,528 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,764篇指南
1指南评论
Thank you for the instructions. Can power to the front control panel be tested without connecting the pressure sensor and water lines.
albert - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 52
过去 30 天: 175
总计 3,239
