跳转到主内容
LG CF360 Front Speaker Replacement
你所需要的
  1. LG CF360 Front Speaker Replacement, Battery: 步骤 1 中的图像 1,2 LG CF360 Front Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Front Speaker Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery.
  3. LG CF360 Front Speaker Replacement, Back Cover: 步骤 3 中的图像 1,2 LG CF360 Front Speaker Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Front Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Front Speaker Replacement: 步骤 5 中的图像 1,3 LG CF360 Front Speaker Replacement: 步骤 5 中的图像 2,3 LG CF360 Front Speaker Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Front Speaker Replacement: 步骤 6 中的图像 1,1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Front Speaker Replacement, Motherboard: 步骤 7 中的图像 1,2 LG CF360 Front Speaker Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  8. LG CF360 Front Speaker Replacement: 步骤 8 中的图像 1,1
    • Gently remove the blue transparent tape from the connector.
  9. LG CF360 Front Speaker Replacement: 步骤 9 中的图像 1,1
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
  10. LG CF360 Front Speaker Replacement, Front Case: 步骤 10 中的图像 1,1
    • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
  11. LG CF360 Front Speaker Replacement: 步骤 11 中的图像 1,1
    • Gently pull the orange ribbon from the number pad casing.
    • Set the number pad case to the side once it is detached from the ribbon.
  12. LG CF360 Front Speaker Replacement: 步骤 12 中的图像 1,1
    • Remove the two red sticker screw coverings at the top corners with tweezers.
  13. LG CF360 Front Speaker Replacement: 步骤 13 中的图像 1,1
    • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
  14. LG CF360 Front Speaker Replacement: 步骤 14 中的图像 1,2 LG CF360 Front Speaker Replacement: 步骤 14 中的图像 2,2
    • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
    • Set the red sliding backing and front cover to the side.
  15. LG CF360 Front Speaker Replacement, Front Speaker: 步骤 15 中的图像 1,1
    • Be very careful to not damage the keypad board when using the plastic opening tool.
    • Gently pry the LCD ribbon from the left side of the front cover using the plastic opening tool.
    • One LCD ribbon is still connected to the keyboard, so do not attempt to remove it from the front cover.
  16. LG CF360 Front Speaker Replacement: 步骤 16 中的图像 1,2 LG CF360 Front Speaker Replacement: 步骤 16 中的图像 2,2
    • Use the plastic opening tool to partially lift up the keyboard from the front of the phone.
    • Slowly rotate the keyboard clockwise while pulling it to the right to disconnect the second LCD ribbon from the keyboard.
    • Remove the keyboard from the phone and set aside.
  17. LG CF360 Front Speaker Replacement: 步骤 17 中的图像 1,1
    • Do not attempt to completely remove the speaker from the phone at this point - it is still connected to the LCD screen.
    • Use the plastic opening tool to pry the front speaker from the phone.
  18. LG CF360 Front Speaker Replacement: 步骤 18 中的图像 1,2 LG CF360 Front Speaker Replacement: 步骤 18 中的图像 2,2
    • Use a soldering iron to desolder the lead junctions. If you have never used a soldering iron or you need a refresher, check out iFixit's soldering guide.
    • Separate the speaker from the LCD screen.
结论
2等其他人完成本指南。
Annie White
于10/18/13注册
262 声望
创作了2篇指南
团队
Cal Poly, Team 4-27, Amido Fall 2013 Cal Poly, Team 4-27, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G27
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 329
