跳转到主内容
Kyocera Hydro Life Charging Port Replacement
你所需要的
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,2 Kyocera Hydro Life Charging Port Replacement, Charging Port: 步骤 1 中的图像 2,2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: 步骤 2 中的图像 1,3 Kyocera Hydro Life Charging Port Replacement: 步骤 2 中的图像 2,3 Kyocera Hydro Life Charging Port Replacement: 步骤 2 中的图像 3,3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: 步骤 3 中的图像 1,1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: 步骤 4 中的图像 1,3 Kyocera Hydro Life Charging Port Replacement: 步骤 4 中的图像 2,3 Kyocera Hydro Life Charging Port Replacement: 步骤 4 中的图像 3,3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: 步骤 5 中的图像 1,3 Kyocera Hydro Life Charging Port Replacement: 步骤 5 中的图像 2,3 Kyocera Hydro Life Charging Port Replacement: 步骤 5 中的图像 3,3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: 步骤 6 中的图像 1,2 Kyocera Hydro Life Charging Port Replacement: 步骤 6 中的图像 2,2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: 步骤 7 中的图像 1,1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: 步骤 8 中的图像 1,1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: 步骤 9 中的图像 1,1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: 步骤 10 中的图像 1,1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 9
总计 990
