跳转到主内容
Kurio Touch 4S Screen Replacement
你所需要的
  1. Kurio Touch 4S Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Make sure to open the back cover easily using the plastic opening tool
  2. Kurio Touch 4S Screen Replacement: 步骤 2 中的图像 1,3 Kurio Touch 4S Screen Replacement: 步骤 2 中的图像 2,3 Kurio Touch 4S Screen Replacement: 步骤 2 中的图像 3,3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Screen Replacement: 步骤 3 中的图像 1,2 Kurio Touch 4S Screen Replacement: 步骤 3 中的图像 2,2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Philips#1 Screwdriver.
  4. Kurio Touch 4S Screen Replacement: 步骤 4 中的图像 1,1
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you get them out of order.
  5. Kurio Touch 4S Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the plastic cover that is covering the camera area.
  6. Kurio Touch 4S Screen Replacement: 步骤 6 中的图像 1,1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Screen Replacement: 步骤 7 中的图像 1,1
    • Use Phillips # 1 screw to open the 4 screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Screen Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Screen Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Screen Replacement: 步骤 10 中的图像 1,2 Kurio Touch 4S Screen Replacement: 步骤 10 中的图像 2,2
    • Detach all the wire that are connected to the motherboard.
    • Also remove the camera module and other components that are attached to the motherboard.
    • For more information on soldering Click here
  11. Kurio Touch 4S Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Screen Replacement: 步骤 12 中的图像 1,1
    • Use the Plastic opener to remove the screen.
    • Do not apply too much pressure as the front cover could be damaged.
  13. Kurio Touch 4S Screen Replacement: 步骤 13 中的图像 1,1
    • Use the soldering tool to remove the wire that is attached to the screen & the motherboard.
  14. Kurio Touch 4S Screen Replacement: 步骤 14 中的图像 1,1
    • Use tweezers to remove the screen from your Kurio Toich 4S.
结论
3等其他人完成本指南。
Ali
于01/21/15注册
184 声望
撰写一个指南
团队
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 的会员
USFT-BROWN-W15S6G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,383
